How many E1s possible on 2610
I have a 2610 router with a NM-1E2W.
How many E1 can I connect in total using the two
WIC ports and the one AIM?
Florian
Re: How many E1s possible on 2610
are you sure you have a working NM-1E2W module installed in a 2610? ref. http://www.cisco.com/univercd/cc/td/doc/pcat/mxne__p1.htm
However, 2610 comes with an ethernet interface, two VIC slots and a NM slot. So you can use the below config which packs 8 E1 ports (v.35 sinalling rather than PRI). You might have throughput problems if all the ports reach close to 100% utilization, suggest adding more memory as well.
CISCO2610 Ethernet Modular Router w/ Cisco IOS IP Software 1
CAB-AC Power Cord,110V 1
S26C-12205 Cisco 2600 Series IOS IP 1
NM-2W 2 WAN Card Slot Network Module(no LAN) 1
WIC-2T 2-Port Serial WAN Interface Card 2
AIM-COMPR2 8 Mbps Compression Adv. Integration Module for Cisco 2600 1
mehmet
you may download the Cisco configmaker, it covers the config details up to 3600. it's downloadable from cisco web.
you may find what you are looking for in the following link: http://www.cisco.com/warp/public/788/products/vwicmf_e1.html
101
