How many PA-2T3+ modules can I put in a 7206VXR?
I also need to have 2 FE interfaces in the 7206VXR to connect it to our backbone. Can you also pass me a link to a document that explains the bandwidth limitations of the 7206VXR and
1 REPLY
Re: How many PA-2T3+ modules can I put in a 7206VXR?
You should consider reviewing this document to answer your question:
http://www.cisco.com/univercd/cc/td/doc/product/core/7206/port_adp/config/3875in.htm
The type and number of port adapters you may install in your router may be influenced by what NPE / NSE you have, how much RAM you have, and the version of IOS you are using. Since those details were not provided in your original question, I cannot give you a reliable answer.
112
