How many port can I monitor in Cat2950?
I have a question in Cat2950.
I could config the port monitor more than two. example) f0/1 -> f0/2, f0/3 -> f0/4.
But I can't config the port monitor more than one, when I config the port monitor more than one, the cat2950 display "Maximum number of monitor ports are already configured".
Is it possible I can monitor more than one more port monitor...
example) f0/1 -> f0/2, f0/4 -> f0/5
Anonymous
N/A
Re: How many port can I monitor in Cat2950?
The document http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/1216ea2b/scg/swgports.htm#xtocid27 should answer your question.
In the section "SPAN Configuration Guidelines":
- Only one SPAN session can be active on a switch at the same time.
- You can have only one destination port.
you can, however have multiple source ports.
You can also refer to this URL
http://www.cisco.com/warp/public/473/41.html#span_cat2950_3550
to get a snapshot of the SPAN feature supported in all cat switches.
95
