11-13-2002 12:15 AM - edited 03-02-2019 02:50 AM
If probe is not avialable, am I right to say that I need to import switches from CW2K then can view real-time info like how it works with a Probe ? Pls help, thanks.
11-13-2002 05:48 AM
For routers you must have a probe to use with RTM. For switches, without a probe, you cannot use the Data Capture in RTM and in Traffic Monitor can only see upto the Data Link Layer Graphs. For seeing Network/Application layer data, you need a probe connected.
11-13-2002 10:13 PM
Your reply was very informative, thanks a lot for your support :)
Thks & Rgds
Zee
