Community Member
How to backup IOS and reinstall IOS using Hyperterminal or Tera Term?
I need to know how to backup and reinstall the IOS image using the Console port and a terminal program.
1 REPLY
Anonymous
N/A
Re: How to backup IOS and reinstall IOS using Hyperterminal or T
First of all you need patience! :-)
What you are trying to do is really time consuming. Nevertheless the way to do it is via X-modem.
The command is .
I hope this helps.
578
