Community Member
How to bind Dialer1 to ISDN B1 channel and Dialer2 to ISDN B2 channel ?
Is it possible to bind Dialer1 to ISDN B1 channel and Dialer2 to ISDN B2 channel on a BRI interface ?
My goal is to achieve that the connection over Dialer1 uses always B1 channel and the connection over Dialer2 uses always B2 channel of a BRI interface.
Community Member
Re: How to bind Dialer1 to ISDN B1 channel and Dialer2 to ISDN B
I believe it is not possible.
What would be the use for it?
Unless you want to monitor what dialer is up by looking at the leds on the interface card.
YES..it is possible..You need to configure dialer profile with "dialer called xxxx" command..Pl. visit here for more on that command
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_r/drfd.htm#xtocid6
The config should look like this
interface bri0
dialer pool-member 1
isdn spid1 xxxx
isdn spid2 yyyy
interface dialer 1
dialer pool 1
dialer called xxxx
interface dialer 2
dialer pool 1
dialer called yyyy
Pl. make sure that the telco delivers the DNIS digits to router when call comes on tht bri..You need to have exact number of digits configured with "dialer called xxxx" command which is received with SETUP message from telco.
So if user calls xxxx which is spid 1, will be binded to interface dialer 1 and yyyy will be binded to dialer 2.
Here is the url which may throw some more lights on that
http://www.cisco.com/warp/public/129/23.html
Community Member
b.jelinek,
I live in Europe (and I do not need to associate a Dialer Virtual Interface to a particular B channel in a BRI) and we do not need SPIDs to configure BRI on a basic net3 type of switches (ELTSI).
How would you do that in such case?
Fabio
115
