Webcast-Catalyst9k
How to busyout a channel on a certain PRI and timout settings.
I have just installed an AS5400 w/ 216 modems and 1 CT3 card and an 8 PRI card. I want to know how to busy out channels on the PRI card. So I will be able to test the failover of PRI's. Also the last problem I'm having is when a user dial's in they get disconnected after a couple of minutes, where to I set the timer for connection time?
Thanks for your help in advance.
Re: How to busyout a channel on a certain PRI and timout setting
You can busyout the channels on pri line using "isdn busy dsl x b_channel 1-24" under the d channel config (interface serial y:23) where x is the dsl number for that line and 1-24 is the range of channels..That command will busyout those channels from AS5400 side..
Now if the connection got disconnected in about 2 mins then it is mostly because of idle-timeout...which is default to two mins..Here is the link which explains it in detail with solution too.
http://www.cisco.com/warp/public/471/idle_timeout.html
thank you,
it worked!
311
