how to cable modem
I have a cisco 1605 R series router with ios 12.0 installed. I have my eth 0 connected to my lan switch and my eth1 is connected to my cable modem. i would like to know how to configure with a dhcp to my cable isp. I think in newer versions of ios you can go to the interface config and type the following : "ip address dhcp" but in my interface i don't see this command. My question is how can i configure with my modem
1 REPLY
Bronze
Re: how to cable modem
The IP ADDRESS DHCP command was introducted in IOS 12.1(2)T, so you will need to upgarde the IOS code before you can give this command.
Refer to the following link:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipras_r/1rfdhcp.htm#1049289
Aslam.
106
