How to change Max CIR bandwidth % which CBWFQ can reserve on FRTS sub-if
On the normal interface we can use default 75% of the interface bandwidth for CBWFQ or LLQ to classified bandwidth for each application. And we can change default the maximum reserved bandwidth 75% by using the command " max-reserved-bandwidth". But I can't use them on the Frame-Relay Point-to-Point subinterface. After I created a frame-relay map-class and define a CIR value. I can use only 50% of CIR to reserve bandwidth for CBWFQ. It will have error messages like the example to warning about not enough bandwidth to reserve. Below is a configuration example and error message.
Example :
class-map match-all HIGH_BW
match ip dscp af41
class-map match-any MEDIUM_BW
match ip dscp af31
policy-map BW_RSV
class HIGH_BW
bandwidth 64
class MEDIUM_BW
bandwidth 64
interface Serial0/0
bandwidth 832
no ip address
encapsulation frame-relay
max-reserved-bandwidth 85
frame-relay traffic-shaping
frame-relay qos-autosense
interface Serial0/0.100 point-to-point
bandwidth 192
backup interface Dialer1
ip address 10.101.255.1 255.255.255.252
frame-relay interface-dlci 100
class FRCLASS
map-class frame-relay FRCLASS
frame-relay adaptive-shaping becn
frame-relay cir 192000
frame-relay bc 36000
frame-relay be 72000
ROMC(config)#map-class frame-relay FRCLASS
ROMC(config-map-class)#service-policy output BW_RSV
I/f Serial0/0.100 DLCI 100 class MEDIUM_BW requested bandwidth 64 (kbps) Available only 32 (kbps)
How I can change the max reserved bandwidth on FRTS class on sub-if or How I can reserved banwidth as my request on FRTS class ?
Re: How to change Max CIR bandwidth % which CBWFQ can reserve on
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Bronze
When using LLQ / CBWFQ with frame relay, the max amount of bandwidth depends on the value of the mincir in the map-class. You have not defined a value for mincir in the map-class, by default it is cir/2 = 96000 bps. You are trying to reserve 128000 bps, which is 32Kbps more than mincir! Try configuring the below:
mincir 128000
now apply the service policy.
186
