03-24-2003 10:46 AM - edited 03-02-2019 06:06 AM
In viewing logs on each of my Catalyst 3500XL Switches I see several Input errors, collisions, CRCerrors, etc. I would like to reset all of the counters and watch what is happening. Any assistance available?!
Solved! Go to Solution.
03-24-2003 11:15 AM
Entering the "clear counters" command in enable mode will clear the counters on all the interfaces. You can also specify which counters you want to clear by entering the "clear int counters
- Matt
03-24-2003 11:15 AM
- Matt
03-24-2003 11:37 AM
Thank you Matt! I was trying just the "clear" command with a ? for additional commands. Just for your FYI....I am doing this in an attempt to determin why some of my workstations are obtaining an Invalid Subnet Mask when the IP Lease is renewing.
Thanks again!
