Webcast-Catalyst9k
How to clear "interface" counters
In viewing logs on each of my Catalyst 3500XL Switches I see several Input errors, collisions, CRCerrors, etc. I would like to reset all of the counters and watch what is happening. Any assistance available?!
1 ACCEPTED SOLUTION
Re: How to clear "interface" counters
Entering the "clear counters" command in enable mode will clear the counters on all the interfaces. You can also specify which counters you want to clear by entering the "clear int counters " Hope this helps..
- Matt
- Matt
Thank you Matt! I was trying just the "clear" command with a ? for additional commands. Just for your FYI....I am doing this in an attempt to determin why some of my workstations are obtaining an Invalid Subnet Mask when the IP Lease is renewing.
Thanks again!
1810
