Community Member
How to clear the counters for Public buffer pools?
Is there a command to clear the counters for the Public buffer pools? I thought 'clear logging' would have done it but it did not.
Thanks in advance,
Steve
1 ACCEPTED SOLUTION
Silver
Re: How to clear the counters for Public buffer pools?
Steve,
No, buffer counters are reflecitive of router uptime so reload is the only way to clear these.
Hope this helps you,
Don
Silver
Steve,
Don
Community Member
Thanks for the quick response and the information!
Steve
165
