how to configure a dialer interface for ISDN link
I have a Bri interface at central & 2 remote routers are dialling the same bri port of central router. I want to make dialer interface on all 3 routers.
I configured dialer string,dialer remote-name , dialer pool , on remote routers.
1) Is it necessary to add ppp multilink on remote routers.
2) Also is username and password for chap required for dialer interface since you don't require it for Bri interface.
3)Do I have to define dialer string at both remote and central router.
1 REPLY
Anonymous
N/A
Re: how to configure a dialer interface for ISDN link
You only need MPPP if you want either of
the remotes to be able to have 2 B
channels up at the same time.
The username command is global, it does
not apply to an interface, and it is required
to accomplish CHAP authentication in
the absense of an external AAA server.
You only have to configure a dialer string
at the box that will be dialing; if a box is
not dialing, the command is not necessary.
Note that you don't have to use dialer
profiles; you can use Legacy DDR.
http://www.cisco.com/warp/customer/129/config-bri-map.html
96
