How to configure a isdn bri interface to dial when the serial interface reaches 90 % of its bandwidth
admin_2
Level 3
Level 3
I need to configure my isdn bri interace to dial and come up when the primary serial interace reaches 90% of the link speed.
Not applicable
your situation looks classic for the backup interface command.
after you configure your bri ,and test the dial works.
go to your serial interface and in interface configuration mode
put these 2 commands
"backup interface bri0/dialer"(if you have dialer profiles.
"backup load 90 60"
the 60 means that when the load on both the interfaces(serial & bri) together,decreases to 60 percent drop the bri which is the backup, you can change the 60 number but that number makes sense.
