how to configure frame-relay svc
Using router 2522 as a frame-relay switch, I want to setup svc connections.
  • Other Network Infrastructure Subjects
1 REPLY
Anonymous
N/A
Re: how to configure frame-relay svc
frame-relay svc
To enable Frame Relay SVC operation on the specified interface, use the frame-relay svc interface configuration command. To disable SVC operation on the specified interface, use the no form of this command
frame-relay svc
no frame-relay svc
Syntax Description
This command has no keywords and arguments.
Default
Disabled
Command Mode
Interface configuration
Usage Guidelines
This command first appeared in Cisco IOS Release 11.2.
SVC operation can be enabled at the interface level only. Once it is enabled at the interface level, it is enabled on all subinterfaces on the interface. One signaling channel, DLCI 0, is set up for the interface, and all SVCs are controlled from the physical interface.
The first use of this command on the router starts all SVC-related processes on the router. If they are already up and running because SVCs are enabled on another interface, no additional action is taken. These processes are not removed once they are created.
Example
The following example enables Frame Relay SVC operation on serial interface 0 and starts SVC-related processes on the router:
interface serial 0
ip address 172.16.3.5 255.255.255.0
encapsulation frame-relay
frame-relay lmi-type q933a
frame-relay svc
314
