10-19-2001 03:45 AM - edited 03-01-2019 06:57 PM
We need to trunk between switch 6509 and 3548 with ISL trunking . Guide me on how to configure trunk ports on both ends.
10-19-2001 07:54 AM
On the 3548
Conf t
Int f0/1
Switchport mode trunk
switchport trunk encapsulation isl
On 6509
set trunk 3/1 on isl
This is assuming that fastethernet 1 on the 3548 is a trunk port along with mod3 port 1 on the 6509.
Issue a 'Show trunk' on the 6509 to see if the trunks are active. If the trunks are not active then disable the port on the 6509 and then enable it again
set port disable 3/1
set port enable 3/1
Hope this helps, if you have further problems you can e-mail me on psherwood@euro-star.com
10-22-2001 04:04 AM
Thanks for your reply , I have successfully configured ISL but my current problem is , I have connected Giga port as Trunk at 3548 and also one fast ethernet is connected and configured to run STP but all the ports are in formwarding stage.
How to solve this issue.
