How to connect 2 LANs on same subnet
Out of curiosity, just to better my knowledge, how can I connect to LANs that are remote from each other using a leased line and still have them in the same network & subnet.
Example siteA 10.0.0.0/8 and siteB 10.1.0.0/8
What devices will I need ?
  • Other Network Infrastructure Subjects
Bronze
Re: How to connect 2 LANs on same subnet
You need to bridge between the two sites (layer 2). Remember that all your broadcasts will also go across the leased line.
A Cisco router can bridge.
Let me know if you need sample config.
pete,
I would be grateful if you could post the sample config. Its OK, I can live with the broadcasts.
I have not tested the config below but it should provide a starting point. '...' is the usual interface configuration. Hope it helps.
bridge irb
interface Loopback0
ip address 10.....
interface FastEthernet0/0
no ip address
bridge-group 1
interface Serial0/0
no ip address
bridge-group 1
interface BVI1
ip address 10....
Do you know of any issues regarding bridging and utilization on the WAN interface, in my case I have 2 3640's (hssi and ATM) over a DS3, but the utilization on both interfaces never goes above 40 %, even when transferring large amounts of data, do you have any idea why, I really appreciate your help, this has been bothering me for a while, thanks again!
Bronze
An issue that commonly pops up with high-bandwidth circuits involves TCP itself. Have a look at http://www.faqs.org/rfcs/rfc1323.html for information on why, depending on the TCP configuration of the end hosts, a single TCP stream may not be able to saturate a high-bandwidth WAN connection.
274
