How to control connections between Vlans
I have a 4006 CatOS switch and Vlans are created for better management. I have two novell servers, which provide remote boot OS services to client PCs, in separated Vlans.
I want to enforce the clients only booting from one fo the servers, how can I achieve this goal?
1 REPLY
Re: How to control connections between Vlans
Are the Novell Servers using IP SLP or IPX? To perform the desired function using a router, you will need to have the servers and clients on different VLANs. If you are running IPX, you may be able to use GNS and GGS filters. For IP, you could just use simple ACLs, but that would prevent any communication to the 2nd server.
91
