Silver
How to determine current SIMMs installed in 2801?
I have a remote 2801 with 128MB DRAM installed, but need to know if it exists of 1 x 128MB SIMM or 2x 64MB SIMM. Is there any way to determine this remotely (like you can with the 3640 series)?
If not, any one happen to know what is the default (1 or 2 banks) for the CISCO2801?
Leo
1 ACCEPTED SOLUTION
Silver
Re: How to determine current SIMMs installed in 2801?
Hi Leo
Cisco 2801 routers have 128 MB of SDRAM soldered onto the system board.. You can install an additional DIMM in the DIMM connector to expand system memory to a maximum of 384 MB.
For more info:
http://www.cisco.com/en/US/products/ps5854/products_installation_guide_chapter09186a00802c5ad8.html#wp1026137
Silver
Hi Leo
For more info:
Silver
HTH,
Thanks for the swift reply.
I found the same link but somehow missed the first line "Cisco 2801 routers have 128 MB of SDRAM installed on the system board. You can install an additional DIMM in the DIMM connector to expand system memory to a maximum of 384 MB"
It does not mention though that the default 128MB DRAm is soldered, so this reply was very helpfull ;-)
112
