Webcast-Catalyst9k
how to disconnect idle dial in users ?
I have a 2611 router with IOS v12.0, on this router are sync/async serial cards , the cards are connected to modems to enable dial in users to connect to the network via modems,the configuration is working ok but I wish to disconnect users who are idle for 5 minutes , what is the IOS command that enables this on the router ? the async lines on the router modems are numbered 1 4 .. thanks in advance..
Re: how to disconnect idle dial in users ?
Have you configured a dialer profile for the users/interfaces ?
If yes, try to use the dialer idle timeout command.
This command will only work if a user is connected to the appropriate dialer.
Let me know if it works !
Simon
yes it worked , thanks :)
Execute the command "session-timeout" in the parameter "line" in mode configuration.
session-timeout-->>Set interval for closing connection when there is no input traffic.
126
