Webcast-Catalyst9k
How to enable applications in CiscoWorks2000?
I have some applications disabled on CiscoWorks2000, such as DFMAD, DFMCP, DFMI. How can I do to enable them?
Blue
Re: How to enable applications in CiscoWorks2000?
There are no such applications like DFMAD, DFMCP in CW2000. Are you referring to some specific DFM processes in CW2000?
I got these information from "Server Configuration -->About the Sever-->Applications and Versions". I do not know exactly all processes about DFM. I want to how to enable the main DFM processes: DfmBroker, DfmServer, DfmMailNotifier, and so on. (I can not find the processes under "Process Management ")
Thanks a lot.
David
Blue
You will only see the above processes under Process Management, if you have installed DFM. Have you installed DFM?
88
