Webcast-Catalyst9k
How to enable CGMP without enabling multicast routing???
Good afternoon,
I have a network architecture of 2 C5500 with RSM/NFFC2 and 4 VLAN's directly attached on a delta configuration: switch dual attached with STP and HSRP redundancy.
I would like to enable CGMP + IGMP snooping to constrain multicats at layer 2 only and not route any multicast traffic between the VLAN's.
Since I need to enable multicast routing on the RSM on all the VLAN interfaces where I will use CGMP, is there a way not to route traffic while still using CGMP?
Here is the configuration:
Multicast Router
Enable the IP multicasting (global command):
ip multicast-routing
Enable each interface running CGMP (interface mode):
ip pim sparse-mode
ip cgmp
Thanks for your help,
Pierre
1 REPLY
Re: How to enable CGMP without enabling multicast routing???
You need a router to act as querier, but don't configure ip multicast-routing on the router.
See:
http://www.cisco.com/warp/public/473/38.html
342
