how to enable routing on 2514
I have an old 2514 running Version 11.0(10c). I have a couple problems. 1) The router does not seem to be routing between the two ethernet interfaces. And 2), how to I reset my passwords so that they are blank? Output from show running-config is below. Thanks in advance!
Rich
cisco-2514#show running-config
Building configuration...
Current configuration:
! Last configuration change at 15:10:37 UTC Tue Oct 18 2005
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname cisco-2514
enable secret xxx.
enable password xxx
interface Ethernet0
ip address 192.168.1.1 255.
interface Ethernet1
ip address 192.168.2.1 255.255.255.0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
no ip classless
ip route 192.168.1.0 255.255.255.0 Ethernet0
ip route 192.168.1.0 255.255.255.0 Ethernet1
line con 0
line aux 0
line vty 0 4
password xxx
login
end
Re: how to enable routing on 2514
Hi Friend,
Few things to be checked...I do not see "ip routing" enabled. Can you please run this command on global config mode and check "sh ip route"
Also I see 2 static routes which I think you do not need because the 2 ethernet interfaces are directly connected and routing will take place automatically.
Please enable ip routing nd also remove the static routes and check, it should work.
ALso to remove both the passwords run this command
no enable secret
no enable password
both on global config mode.
Ankur
Hall of Fame Super Silver
Ankur
The ip routing command is on by default and does not show up in show running-config. We can verify whether ip routing is enabled with show protocol and show ip protocol.
I agree that the static routes are not needed and just confuse the issue. In fact I think it is a bit worse since both static routes are for the same network (which is the connected network of ethernet 0) and point to both ethernet 0 and ethernet 1 as ways to get there. The static routes are centainly not helping and should be removed.
I note that ethernet 0 does not have a valid mask in the configuration. I do not know whether this is just something wrong in cut and paste or if there is a real problem with the interface. I think it might be quite helpful if Rich who sent the original post could post the output of show ip protcol and of show ip interface.
It would also be interesting to know a bit more about how the router is set up. What is connected on ethernet 0 and what is connected on ethernet 1. Can the router ping (standard ping) to any device on ethernet1? If so can the router also do an extended ping to the device on ethernet 1 and specify the source is the address of ethernet 0? I am wondering if there might be issues with the default gateway definitions of the end stations.
Rick
435
