How to filter incoming routes
Would anyone please tell me how to write access-list to filter incoming routes as follows?
Incoming Routes:
10.0.0.0/8, 10.0.0.0/9, 10.10.0.0/16
Wanted Route:
10.0.0.0/8
I have tried to use the following methods but it didn't work:
Method 1 --
distribute-list 10 in
access-list 10 permit 10.0.0.0
Result => Only 10.10.0.0/16 is filtered
Method 2 --
access-list 10 permit 10.0.0.0 0.255.255.255
Result => no routes are filtered.
Method 3 --
distribute-list 101 in
access-list 101 permit ip 10.0.0.0 0.0.0.0 255.0.0.0 0.0.0.0
Result => all routes are filtered.
I don't know how to write access-list to control the incoming routes down to subnet mask.
Thanks!!!!
Re: How to filter incoming routes
Try this
Method 4 --
distribute list 100 in
access-list 100 permit ip 10.0.0.0 0.255.255.255 255.0.0.0 0.255.255.255
I didn't try it, but hope it works.
/Rustam
You might want to try a permit statement of 10.0.0.0 0.0.0.0
That is an exact match of 10.0.0.0. However, there might be better ways to go about it depending on your overall network. Just not redistributing subnets would be one example I think.
You could also look at using a prefix-list. Depending on what routing protocol you are using
changes the way you apply it.
Ex. ip prefix-list prefix-list-name permit 10.0.0.0/8
router bgp 100
network 20.1.1.1
neighbor 30.1.1.1 remote-as 300
neighbor 30.1.1.1 prefix-list prefix-list-name in
This would only allow the 10.0.0.0/8 network and deny
every other network. I haven't tested this but it is another way to filter at the net prefix.
Thanks a lot for all of them!!!
Before reading your reply, I tried to use Prefix-list to do route filtering. I'm very surprise that the prefix-list can be applied on any classless routing protocols, not just BGP. I'd like to share with you.
Sure-Win Method -- :>
router eigrp 10
distribute-list prefix TEST in
ip prefix-list TEST seq 1 permit 10.0.0.0/8
Result => Only 10.0.0.0/8 is received.
111
