Community Member
how to find fan tray sreial no
Hi All,
i have 5500 switch in which we are using cat ios and fan tray is failing now and then i want o find the part number and serial number for the fan tray...
For native ios the command is there i.e
show idprom fan-tray but cat ios i could not find any
help required and also the fan tray in 5500 series are hotswapple or one has to reboot the switch because in 4500 seires when you change the fan tray
one needs to restart the switch it is bug in 4500 series but can any body tell about 5500 series..
regards
Sandeep chugh
1 REPLY
Silver
Re: how to find fan tray sreial no
130
