How to find IP of SUP card from MSFC in Catalyst 6509 switch
I have logged into the MSFC of 6509, and want to login to the SUP engine. I don't know the IP of SUP. Is there any way I can get the info from MSFC so that I can login to SUP or is there any command on MSFC like session <mod number> which we use to login to MSFC from SUP.
Re: How to find IP of SUP card from MSFC in Catalyst 6509 switch
Hi Sourabh,
Are you running your switch in HYBRID mode is yes can you give a try with "sh cdp nei det" command as I remember that we can see the sup from MSFC via CDP on Hybrid mode.
Try that and update if that works.
Ankur
Hi Ankur,
switch is running in HYBRID mode.
when i do sh cdp nei det on MSFC, i am not getting any entry displayed, so i believe that we cant see sup from msfc via CDP
Sourabh
Guys,
any thoughts ?
appreciate your help !
i think u can get it through sh cdp nei det
below is the output my 6509.
MDD-Router#sh cdp neighbors detail
Device ID: SCA0520022G(6509)
Entry address(es):
IP address: xxxx.xxx.xx.x
Platform: WS-C6509, Capabilities: Trans-Bridge Switch
Interface: Vlan1, Port ID (outgoing port): 15/1
Holdtime : 172 sec
Version :
WS-C6509 Software, Version McpSW: 8.3(5) NmpSW: 8.3(5)
Copyright (c) 1995-2004 by Cisco Systems
advertisement version: 2
VTP Management Domain: 'xxxxxxx'
There is no entry for any device when i do sh cdp nei on MSFC.
I have checked that CDP is running on switch.
Router>sh process | incl CDP
41 Mwe 404232D0 28 18769 1 5428/6000 0 CDP Protocol
Purple
Sure its not a native box ???? If it was a hybrid it "would" show in cdp even if the fields were blank. See if you can do a show mod command and post . Also a show version might help.
Switch is running in hybrid mode. here is the output of sh mod and sh ver.
Switch> sh module
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP2-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
2 2 24 100BaseFX MM Ethernet WS-X6324-100FX-MM no ok
3 3 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
Mod Module-Name Serial-Num
1 SAL08144HGQ
15 SAL0811W7M0
2 SAD05400437
3 SAL050212BD
Mod MAC-Address(es) Hw Fw Sw
1 00-0f-8f-9d-27-92 to 00-0f-8f-9d-27-93 5.0 7.1(1) 6.3(10)
00-0f-8f-9d-27-90 to 00-0f-8f-9d-27-91
00-07-84-f6-6a-c0 to 00-07-84-f6-6e-bf
15 00-0f-34-39-fc-c0 to 00-0f-34-39-fc-ff 2.6 12.1(13)E1 12.1(13)E12
2 00-03-32-85-6f-ec to 00-03-32-85-70-03 3.0 5.4(2) 6.3(10)
3 00-05-5f-2a-83-08 to 00-05-5f-2a-83-37 3.1 5.4(2) 6.3(10)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw
1 L3 Switching Engine II WS-F6K-PFC2 SAL08144GQM 3.4
Router>sh ver
IOS (tm) MSFC2 Software (C6MSFC2-DSV-M), Version 12.1(13)E12, EARLY DEPLOYMENT R
ELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Sat 22-Nov-03 07:16 by hqluong
Image text-base: 0x40008C00, data-base: 0x419F4000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: MSFC2 Software (C6MSFC2-BOOT-M), Version 12.1(13)E12, EARLY DEPLOYMENT
Router uptime is 2 days, 4 hours, 31 minutes
System image file is "bootflash:c6msfc2-dsv-mz.121-13.E12.bin"
cisco Cat6k-MSFC2 (R7000) processor with 458752K/65536K bytes of memory.
Processor board ID SAL0811W7M0
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
509K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x102
725
