How to fix a speed of a mica modem
I've a 3745 router (IOS 12.2(11)T9) with a mica-6DM (Portware 2.7.3) integrated.
I've some application that only work at a speed of 2400 bits/s and consequently I want to fix the minimum and maximun speed at 2400.
The problem is that it's running fine during some days and suddenly the speed is changing automaticaly for no apparent reason. Can you help me to solve the problem ? Below you find the important point of my configuration.
aaa new-model
aaa authentication banner ^C^C
aaa authentication login BONE group radius
aaa authorization exec BONE group radius
aaa accounting network BONE start-stop group radius
aaa session-id common
modem country mica spain
isdn switch-type primary-net5
modemcap entry mcom:AA=S30=2400S31=2400
controller E1 1/0
pri-group timeslots 1-31
interface Serial1/0:15
no ip address
isdn incoming-voice modem
no cdp enable
radius-server host 10.10.2.1 auth-port 60005 acct-port 0
radius-server key 7 <removed>
radius-server authorization permit missing Service-Type
line 97 126
exec-timeout 0 0
no flush-at-activation
login authentication BONE
modem Dialin
modem autoconfigure type mcom
escape-character NONE
1 REPLY
Silver
Re: How to fix a speed of a mica modem
The workaround is to use a modemcap using a different value of S29, and/or S30 to limit the top rate, and/or S64 to use a fixed modulation. Examples:
modemcap entry v22bis:MSC=&f&d2s29=4
This will automode with the top modulation being V.22bis (2400 bps)
So try to change the value of s29=4 , this mayfix your problem
110
