How to fix "%PA-2-UNDEFPA" ?
Hi, sir
There is cisco7204 with NPE150.
System Bootstrap, Version 11.1(5) [mkamson 5], RELEASE SOFTWARE (fc1)
C7200 processor with 49152 Kbytes of main memory
IOS (tm) 7200 Software (C7200-IS56I-M), Version 12.1(15), RELEASE SOFTWARE (fc1)
Slot 3 with PA-2H.
reload 7204 message below:
%PA-2-UNDEFPA: Undefined Port Adaptor type 130 in bay 3
%PA-3-DEACTIVATED: port adapter in bay [3] powered off.
%SYS-4-CONFIG_NEWER: Configuration from version 12.1 may not be correctly understood
Please kindly tell how to fix ? Thank you.
Re: How to fix "%PA-2-UNDEFPA" ?
Was this PA-2H card working fine before? Looks like it needs a newer IOS. Can you paste the output of sh ver
http://www.cisco.com/cgi-bin/Support/Errordecoder/error_decoder.pl?index=ios&query=PA-2-UNDEFPA&counter=0&paging=5&links=reference&sa=Submit
Try the software advisor to determine what software version you need
http://www.cisco.com/cgi-bin/Support/CompNav/Index.pl?Introduction=True
This PA-2H working fine before. even have the UNDEFPA message, the PA-2H
still working fine.
Copyright (c) 1994 by cisco Systems, Inc.
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
Self decompressing the image : ######################################################
########### [OK]
%SYS-4-CONFIG_NEWER: Configuration from version 12.1 may not be correctly understoodC
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
Read 9397492 bytes from file slot0:c7200-is56i-mz.121-15.bin
########################################## [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 14-May-02 00:07 by kellythw
Image text-base: 0x60008950, data-base: 0x6169E000
Compliance with U.S. Export Laws and Regulations - Encryption
This product performs encryption and is regulated for export
by the U.S. Government.
This product is not authorized for use by persons located
outside the United States and Canada that do not have prior
approval from Cisco Systems, Inc. or the U.S. Government.
This product may not be exported outside the U.S. and Canada
either by physical or electronic means without PRIOR approval
of Cisco Systems, Inc. or the U.S. Government.
Persons outside the U.S. and Canada may not re-export, resell,
or transfer this product by either physical or electronic means
without prior approval of Cisco Systems, Inc. or the U.S.
Government.
cisco 7204 (NPE150) processor (revision B) with 43008K/6144K bytes of memory.
Processor board ID 3652088
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
4 slot midplane, Version 1.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
16 Serial network interface(s)
2 HSSI network interface(s)
125K bytes of non-volatile configuration memory.
1024K bytes of packet SRAM memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
Press RETURN to get started!
00:00:09: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
00:00:09: %LINK-3-UPDOWN: Interface Serial1/0, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial1/1, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial1/2, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial1/3, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial1/4, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial1/5, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial1/6, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial1/7, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial2/0, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial2/1, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial2/2, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial2/3, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial2/4, changed state to down
00:00:09: %LITACNK-3-UPDOWN: Interface Serial2/5, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial2/6, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial2/7, changed state to down
00:00:09: %LINK-3-UPDOWN: Interface Hssi3/0, changed state to up
00:00:09: %LINK-3-UPDOWN: Interface Hssi3/1, changed state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, ch
anged state to up
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/1, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/2, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/3, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/4, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/5, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/6, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/7, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/2, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/3, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/4, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/5, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/6, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/7, changed
state to down
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Hssi3/0, changed st
ate to up
*Aug 16 06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Hssi3/1, changed st
ate to down
*Aug 16 06:07:34: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 16 06:07:35: %SYS-5-RESTART: System restarted --
*Aug 16 06:07:35: %SYS-6-BOOTTIME: Time taken to reboot after reload = -24828 seconds
*Aug 16 06:07:35: %LINK-5-CHANGED: Interface Serial1/0, changed state to administrati
vely down
*Aug 16 06:07:35: %LINK-5-CHANGED: Interface Serial1/1, changed state to administrati
vely down
*Aug 16 06:07:35: %LINK-5-CHANGED: Interface Serial1/2, changed state to administrati
vely down
*Aug 16 06:07:35: %LINK-5-CHANGED: Interface Serial1/3, changed state to administrati
vely down
*Aug 16 06:07:35: %LINK-5-CHANGED: Interface Serial1/4, changed state to administrati
vely down
*Aug 16 06:07:35: %LINK-5-CHANGED: Interface Serial1/5, changed state to administrati
vely down
*Aug 16 06:07:35: %LINK-5-CHANGED: Interface Serial1/6, changed state to administrati
vely down
*Aug 16 06:07:35: %LINK-5-CHANGED: Interface Serial1/7, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Serial2/0, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Serial2/1, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Serial2/2, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Serial2/3, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Serial2/4, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Serial2/5, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Serial2/6, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Serial2/7, changed state to administrati
vely down
*Aug 16 06:07:36: %LINK-5-CHANGED: Interface Hssi3/1, changed state to administrative
ly downACS+ Authentication is ENABLED in this router TP-7204!!Checking TACACS+.......
Sorry, TACACS+ Authentication is disable, use ENABLE PASSWORD to enter!!!
Password:
*Aug 16 06:07:48: %DUAL-5-NBRCHANGE: IP-EIGRP 1: Neighbor 10.64.111.241 (Hssi3/0) is
up: new adjacency
TP-7204#sh log
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
Console logging: level debugging, 61 messages logged
Monitor logging: level debugging, 0 messages logged
Buffer logging: level informational, 61 messages logged
Trap logging: level informational, 65 message lines logged
Logging to 10.64.24.5, 65 message lines logged
Log Buffer (4096 bytes):
06:07:34: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state t
o down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
state to down
ate to up
ate to down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
vely down
ly down
up: new adjacency
Aug 16 13:03:57: %STANDBY-6-STATECHANGE: FastEthernet0/0.106 Group 15 state Standby -
> Active
Aug 16 13:03:57: %STANDBY-6-STATECHANGE: FastEthernet0/0.107 Group 17 state Standby -
> Active
Your bootstrap version 11.1(5) does not recognize the adapter while booting (which is ok) so it generates an error message. Your IOS 12.1(15) does not have any problems recogizing the card so it brings it up and it works fine.
If you want to get rid of the error message load a higher boot version of the IOS. This way you make sure that the card works even if the router just boots the bootstrap IOS.
191
