How to generate LABP Disconnect on a router
For technical training we need a to force a "clean" LAPB Disconnect. How do we force such normal clean on a Cisco 2611 with a X.25 connection to a X.25 Switch ?
With "int s0/0, shutdown", the router simply put the RTS Signal OFF. And I didn't found any clear command that force a LABP Disconnect message to be send.
  • Other Network Infrastructure Subjects
1 REPLY
Anonymous
N/A
Re: How to generate LABP Disconnect on a router
With an X25 interface, the best that you
can do is to clear the X25 interface or VC
which will cause a RESATART to be sent at
the X25 layer. There isn't a way to generate
any LAPB DISCONNECT frame via the exec
CLI.
232
