09-10-2002 01:40 PM - edited 03-02-2019 01:15 AM
if I logg into the router I do I go back into the switch from here
09-10-2002 03:08 PM
I'm assuming you are asking how to get to the Supervisor from the MSFC. If you used the "session" command, you type in "exit". If you used the "switch console" command, press control C 3 times
09-11-2002 10:00 AM
No, this does not work.
1st off I am logged into the MSFC Router prompt and I would like to go to the switch config from here without killing the session. You state to type in switch console command.. Is this what I type or something else.
Jeannene
09-11-2002 10:27 AM
How do you get logged into the MSFC Router prompt? Do you telnet directly using an IP address? If so the only way to get to the switch would be to do a "sh cdp neighbor detail" get the IP address of switch and telnet to that IP
