Community Member
How to load an IOS into Flash ....
I have "lost" the IOS from Flash, but at least it was backed up on a laptop/TFTP server. Now I can't find the proceedure to load the IOS.
Any help with a link to find the proceedure would be appreciated.
hkohl@netzero.net
1 ACCEPTED SOLUTION
Re: How to load an IOS into Flash ....
Cant say anything until you say the type of router you have.
You can find upgrading procedures about any Cisco router from the following link. You willhave to select the appropriate router model and search through Software configuration / Troubleshooting links.
http://www.cisco.com/pcgi-bin/Support/browse/index.pl?i=Hardware%20Products&f=505
Silver
what kind of router is it ?
Community Member
It is a 2620 .... Realized I forgot that and came back to update the original question
Silver
318
