How to load balance two link (resilient link)
How to load balance (if can) or failover two Fiber channel like as below?
interface GigabitEthernet0/1
switchport mode trunk
channel-group 1 mode active
channel-protocol lacp
interface GigabitEthernet0/2
1 REPLY
Re: How to load balance two link (resilient link)
You can use this "port-channel load-balance src-dst-ip", this will do a XOR on source & destination IP addresses and choose the interface G0/1 if the first bit of the result is 0 or the interface G0/2 if the first bit of the result is 1.
But you can check the path used with that command: "sh etherchannel 1 port-channel"
You can load balance with the mac-addresses too (it is the default mode I think)
http://www.cisco.com/warp/public/473/4.html
Rate if it helps.
MB
246
