08-22-2003 05:13 AM - edited 03-02-2019 09:49 AM
What are the proper steps to migrate an EIGRP environment to OSPF? We have four sites total.
Thanks.
08-22-2003 05:25 AM
Hi Minh,
Here's a very good document on EIGRP to OSPF by Michael Gibbs,CCIE#7417 of Riverstone Networks.
'EIGRP to OSPF Migration Strategies'
Hope this helps -
08-22-2003 05:29 AM
***SORRY FORGOT TO ADD THE URL***
http://www.riverstonenet.com/pdf/eigrp_to_ospf_migration.pdf
Thanks --
08-28-2003 08:25 AM
Thanks for the article. I have a question though. Where would you recommend creating Area 0? I have three sites. HQ has 4 routers (2 at the edge and 2 in the core). The other two remote sites have one WAN router each.
Thanks.
08-28-2003 08:59 AM
First I would like to know if you can tell us, the reasons why you want to migrate from EIGRP to OSPF. DO you have any vendor equipment other than Cisco ?
08-28-2003 10:06 AM
All Cisco now, but bringing in other equipments.
08-28-2003 01:42 PM
If all your Routers (not other equipment) are going to be Cisco, there is no gain that you achieve by migrating to OSPF.
Regarding your question, Your network is really small and would not matter, if you put all of them in a single area.
08-28-2003 01:19 PM
For this small of a network, I would make the entire network area 0. Of course, I wouldn't migrate a network from EIGRP to OSPF, unless I had a very specific reason to do so, and clearly defined goals for doing it. :-)
There is no "best" routing protocol, regardless of what you may hear different people say. It's all a matter of your network design, and what you are trying to do.
Russ.W
09-04-2003 10:22 AM
Hi Russ,
I heard some comment from other network engineer that eigrp doesn't scale well and I wonder what's the limit (like how big is too big)?
We're using eigrp as our internal routing protocol, and we have less than 20 routers involved, in this case, I don't think we need to switch the protocol to ospf, at least I haven't encountered any problem with eigrp at this point. Do you have any suggestion?
Charlene
09-04-2003 11:38 AM
I wouldn't switch, unless I had some specific capability or reason to.... EIGRP not scaling? I don't know... I know of several EIGRP networks over 2000 routers, which seems pretty big to me.... :-) I know that with EIGRP, if you summarize right, and bound your queries right, there's really no limit in terms of routers.
Russ.W
09-05-2003 06:27 AM
Scaling of either EIGRP or OSPF is a matter of proper design. Each is better than the other under certain conditions, either will fail bigtime if used in a network which is not designed to avoid their weaknesses. Both can handle a few thousand routers if the design is good, neither can handle more than a few dozen if performance is critical and the design is bad.
Good luck and have fun!
Vincent C Jones
