03-13-2003 07:42 AM - edited 03-02-2019 05:51 AM
Does any one knows a way to monitor a rate-limit (bytes conformed, bytes dropped, etc) and access-lists (matches) through a SNMP monitoring application such as MRTG???
TIA
03-18-2003 12:41 AM
with MRTG you can collect Datas from all snmp mib-vars, so so can monitor a lot of values very easy. all you need is to find the right OID.
have a look at:
http://www.cisco.com/cgi-bin/Support/Mibbrowser/unity.pl?o=1.3.6.1.4.1.9.2.2.1.1&t=yes&st=3#oid
to find the mib-var needed.
If you once have generated a MRTG config-File using cfmaker (..) you can edit the configfile and add the collections you want.
I dont know about access-list match counter-mib
regards Phil
03-18-2003 05:10 AM
Thanks 4 your help
This was what i needed!!!!
