Webcast-Catalyst9k
How to Monitor Cisco 1751
Hi All,
Does somebody knows if it's possible to monitor using Telnet and Cisco IOS how the router is working (movements of packets, CPU use, etc.).
If it's possible, what are the commands to activate this monitoring?
Best Regards,
Igor Sotelo.
1 ACCEPTED SOLUTION
Blue
Re: How to Monitor Cisco 1751
You can use the CLI commands like show proc cpu, show intefrace to view these details.
Blue
And btw, how do I see from second to second, how the packets are moving and how the CPU use is changing?
Well you can see the packets by "sh interface" look for incrementing errors. The other post was right on the money. "Sh proc cpu" it gives different time interval readings for your cpu.
95
