How to monitor class/policy-maps
Please review the following config. Does anyone know what is the best way to monitor that this is doing what is supposed to do? When I apply this config the users complain about slow performance. Help anyone?..
class-map match-all SNA
match access-group name DLSW
policy-map SNA-PRIORITY
class SNA
bandwidth percent 40
random-detect
random-detect exponential-weighting-constant 4
random-detect precedence 1 20 40 1
set precedence 1
interface Serial1/0/8:7
bandwidth 1536
ip address xxxxxxxxxxxxxxxxxx
ip load-sharing per-packet
max-reserved-bandwidth 100
service-policy output SNA-PRIORITY
ip access-list extended DLSW
permit tcp any any eq 2065
permit udp any any eq 2067
Silver
Re: How to monitor class/policy-maps
There are 2 commands that I can think of:
sho policy-map int Serial1/0/8:7 ; and
sho queue int int Serial1/0/8:7.
The first one displays the conformed/exceeded/dropped statistics, and the second one should display the queue stats.
You may also want to try using QDM:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/qdm/index.htm
Also, could you explain further what you are trying to achieve by this class map? Is Low Latency Queueing an option?
hth,
Mustafa
Thanks for your help.
I am trying to prioritize SNA traffic by reserving at least 40% bandwidth for DLSW. I considered Queuing but class-maps are the recommended way by Cisco.
125
