How to prevent an Interface from shutting down due to excessive errors?
How to prevent an Interface from shutting down due to excessive errors on a CAT 3550. Apparentky there is a error detect cause all and error recovery cause all and some error timer commands. Which are the right sequence of commands to use, so that in spite of excessive errors an interface doesn't shut itself down?
See Log File of my router, I then manually did a no shut on Interface FA0/2/
Jun 20 09:40:35.600: %ETHCNTR-3-HALF_DUX_COLISION_EXCEED_THRESHOLD: Collision at FastEthernet0/2 exceed threshold. Consider as loo
Jun 20 09:40:35.600: %ETHCNTR-3-LOOP_BACK_DETECTED: Loop-back detected on FastEthernet0/2. The port is forced to linkdown.
Jun 20 09:40:37.600: %LINK-5-CHANGED: Interface FastEthernet0/2, changed state to administratively down
Jun 20 09:40:38.600: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/2, changed state to down
Jun 23 09:36:01.784: %LINK-3-UPDOWN: Interface FastEthernet0/2, changed state to down
Bronze
Re: How to prevent an Interface from shutting down due to excess
As far as I know, there is not an option to prevent the switch from disabling itself due to the collisions. You can configure the "errdisable recovery" command to allow the interface to recover from the error-disabled state without having to manually entering shut/no shut. Refer to the following links for more information:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc6/cli/clicmds.htm#xtocid28
I would investigate why you are getting these errors. Looks like a speed or duplex mismatch on the link.
112
