12-10-2003 10:18 AM - edited 03-02-2019 12:16 PM
I have a policy-map on both ends of a 100MB link in order to prioritize voice traffice. The policy-map looks like this:
class-map match-any Voice-Control
match ip dscp af31
match ip dscp ef
interface FastEthernet0/0
description 100MB XO Link to Spokane
ip address xxx.xxx.xxx.xxx
service-policy output Voice-Policy
policy-map Voice-Policy
class Voice
priority 10000
class Voice-Control
bandwidth 500
class class-default
fair-queue
Someone is going to FTP many 600+MB files over the next couple of days and I want to make FTP the lowest priority to insure these file transfers don't cause any congestion grief on the link.
What is the best way to add to, or change, this policy-map to make FTP the lowest priority?
12-10-2003 01:16 PM
with the current configuration, the default class covers your FTP traffic. If you want to have FTP traffic as the lowest priority, I would add two more classes to the existing policy, one that allows FTP traffic and one that denies FTP traffic:
class match-all NO_FTP
match ip address 101
class match-all FTP
match ip address 102
access-list 101 deny tcp any any eq ftp
access-list 101 permit ip any any
access-list 102 permit tcp any any eq ftp
access-list 102 deny ip any any
class NO_FTP
set precedence 5
class FTP
set precedence 4
This way, all traffic gets precedence over FTP traffic.
Georg
12-11-2003 05:40 AM
Config is right but one more important thing:
101 and 102 ACLs cover only FTP control channel (TCP 21). But FTP data flow will be from FTP data channel (TCP 20) and therefore for 101 ACL should be:
access-list 101 deny tcp any any eq ftp-data
access-list 101 deny tcp any eq ftp-data any
access-list 101 permit ip any any.
I've added to and from TCP 20 thinking that FTP data flow may be sourced from both sides. And 102 ACL should be modified this way.
