s.m
how to provide 4MB from 4T module in 3660
Is it possible to use my 4T Netowrk Module to provide cumulatively above 4MB or =4MB of data rate to a client of mine.
In a support page i have come accross where i can realise my 4T module to provide 8MB data rate.
If so , is it possible to provide 4MB and still use my other modules for other links.
kvc
Re: how to provide 4MB from 4T module in 3660
hi,
It is possible to take 4mb from a single port.
I am not sure which port. It is either port2 or port3 on the nm-4t module.
you can use the other ports for other links.
But i think you will not be able to use the 4th port which is for 8mb.
s.m
hi kvc...thanks for replying
Can u gimme a hint as to how will i be able to do it....some hardware changes or through command line only.....i mean by just adding something to the config thru command line.
kvc
hi,
There are no config changes required.
In NM-4T card if i use the fourth port only and all other ports are not being used then i can derive full
8mb from that port.
If i am using the third port and no other port
then i can use 4mb from it. If i use the 2nd and 1st port also then i get 2mb for 1st and 2mb for second port also. In altogether 4+2+2.( but in this case you cannot use the 4th port).
109
