Community Member
how to regenerate a certificate for 2821
Hello Cisco,
I have a cisco 2821 running Version 12.4(6)T3,
I issued a write erase and cleared off the following two certificate;
crypto pki trustpoint
crypto pki certificate
Can someome please tell me what steps I need to take to restore both
Certificate if possible.
Any help would be greatly appreciated.
thx charlie
Router#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(6)T3, RELEASE SOFTWARE (fc2)
Technical Support:
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 21-Jul-06 16:16 by kellythw
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Router uptime is 55 minutes
System returned to ROM by reload at 19:23:16 UTC Thu Sep 14 2006
System image file is "flash:c2800nm-advipservicesk9-mz.124-6.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2821 (revision 53.51) with 512000K/12288K bytes of memory.
Processor board ID FTX1034A4E9
2 Gigabit Ethernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Router#dir flash
%Error opening flash:/flash (File not found)
Router#dir flash:
Directory of flash:/
1 -rw- 36226996 Aug 25 2006 04:43:52 +00:00 c2800nm-advipservicesk9-mz.124-6.T3.bin
2 -rw- 1826 Aug 25 2006 04:59:24 +00:00 sdmconfig-28xx.cfg
3 -rw- 4734464 Aug 25 2006 05:00:08 +00:00 sdm.tar
4 -rw- 833024 Aug 25 2006 05:00:42 +00:00 es.tar
5 -rw- 1052160 Aug 25 2006 05:01:18 +00:00 common.tar
6 -rw- 1038 Aug 25 2006 05:01:50 +00:00 home.shtml
7 -rw- 102400 Aug 25 2006 05:02:20 +00:00 home.tar
8 -rw- 491213 Aug 25 2006 05:02:50 +00:00 128MB.sdf
9 -rw- 1684577 Aug 25 2006 05:03:34 +00:00 securedesktop-ios-
10 -rw- 398305 Aug 25 2006 05:04:12 +00:00 sslclient-win-
256507904 bytes total (210964480 bytes free)
Router#cd nvram:
Directory of nvram:/
238 -rw- 771 <no date> startup-config
239 ---- 24 <no date> private-config
240 -rw- 771 <no date> underlying-config
1 -rw- 0 <no date> ifIndex-table
2 -rw- 595 <no date> IOS-Self-Sig#3201.cer
245752 bytes total (242857 bytes free)
Re: how to regenerate a certificate for 2821
To enable key rollover with manual certificate enrollment, use the regenerate command in ca-trustpoint configuration mode.Do not regenerate the keys manually; key rollover will occur when the crypto ca enroll command is issued.Refer the following URL
