How to Restrict Per Port Bandwidth on Cat3550 Switch
I would like to use a Cat3550 Switch (WS-C3550-48-EMI) in an ISP setup, where each 10/100 MBPS ports will be used for providing connectivity with the customers.
Switch IOS Version 12.1(14)EA1a.
Now I like to restrict bandwidth of each 10/100 MBPS ports of the switch to say 128 KBPS for a particular customer. Can anybody help me describing how to implement this.
Warm regards,
Malay.
  • Other Network Infrastructure Subjects
VIP Purple
Re: How to Restrict Per Port Bandwidth on Cat3550 Switch
Hello Malay,
for the 3550 with EMI there are numerous QoS options available to limit the traffic on 10/100 ports. You could use classes and limit traffic by ACL, class maps, policy maps, and aggregate policers. Not sure how much experience you have with these configurations, but you might want to check this document:
CISCO CATALYST 3550 SERIES SWITCHES
Configuring QoS
http://www.cisco.com/en/US/partner/products/hw/switches/ps646/products_configuration_guide_chapter09186a008014f36e.html
GP
Hi Georg,
Thanks a lot for the input. I'm going through the document for Configuring QoS on Cat 3550. As I'm not conversant with this, it will take some time for me to be well conversant and choose the best suited option for my purpose. I would be very much thankful if you can suggest some solution which would suit my requirement, which I believe you understood well.
Warm regards,
Malay.
103
