How to set 2 VLANS on 1 port on a catalyst switch?
I have a 1711 router with 1 physical ethernet interface. I have it configured for 2 sub-interfaces - vlan2 and native vlan1. This will be plugged into a Catalyst2950 switch port. Right now all ports on the switch are defaulted to vlan1. Is there a command on the switch where I can just set that 1 port to recognize the two vlan tags(vlan2 & native vlan1) that was set on the router making the router itself recognizable by other machines on the vlans?
Thank you,
Lee
1 REPLY
Re: How to set 2 VLANS on 1 port on a catalyst switch?
Hi Lee,
You can use trunking to allow multiple vlans in a switch and also use dot1q encapsulation on the appropriate sub-if.
regards
91
