How to set dot1q trunk between 2900xl and Foundry FastIron switch
I have a 2900XL, FX prot 23 set with
swithport mode trunk
switchport trunk encap dot1q
Its connected to a Foundry Fastiron Backbone( 16 FX ports, 100M)
How do I set the a port on foundry box to use dot1q ?
Re: How to set dot1q trunk between 2900xl and Foundry FastIron s
the default encapsulation in the Foundry is dot1q,so you just type :
vlan *
tag e16
Thanks for your reply
The foundry switch in question, is discontinued product.It is a Fast Iron Backbone with 16 100M Fx ports.
I some how acquired the latest upgrade code
(7.1) but the documentation on the Foundry wesite does not seem to apply ( e.g the
FastIron(config)cdp run --> command does not work witht he new code)
So my qustion is does the switch still by default had dot 1q ?
How can I confirm ?
The commands you have suggessted "vlan *"
will only allows me to configure a port with that particular vlan. Then the Cisco device fed from the founundy trunk port will not allow more than one vlan.
I have to set multiple vlans on the end cisco device ?
291
