How to set Ethernet speed on 7200
I am trying to set the interface speed at 100M at FE interface on 7200 but its not working. Pls see the attached file for more information. Any help will be appriciated. Thanks
Gold
Re: How to set Ethernet speed on 7200
I have 7200 with no problem:
7200(config)#interface fastEthernet 2/0
7200(config-if)#speed ?
10 Force 10 Mbps operation
100 Force 100 Mbps operation
auto Enable AUTO speed configuration
running:
c7200-ik9o3s-mz.124-3d.bin
12.2 is quite old image maybe upgrade will fix this
M.
Thanks. I have another 7200 with IOS (tm) 7200 Software (C7200-P-M), Version 12.0(21)ST7 image and on this Its working fine.
Silver
please, try setting first:
"duplex full" and then "speed 100".
Also you can try another setting for "media-type".
121
