Community Member
How to set-up privilege accesses level in Cisco 4006 cat switch?
I could not find this information on Cisco web site
CAT4006-S1> (enable) sh ver
WS-C4006 Software, Version NmpSW: 7.4(2)
Copyright (c) 1995-2002 by Cisco Systems, Inc.
NMP S/W compiled on Oct 8 2002, 18:12:59
GSP S/W compiled on Oct 08 2002, 15:54:51
System Bootstrap Version: 6.1(5)
Hardware Version: 2.0 Model: WS-C4006 Serial #: FOX05330QBF
Mod Port Model Serial # Versions
1 2 WS-X4013 JAB050700C5 Hw : 2.0
Gsp: 7.4(2.0)
Nmp: 7.4(2)
2 48 WS-X4448-GB-RJ45 JAB0706007V Hw : 1.1
4 34 WS-X4232-L3 JAB042500VV Hw : 1.7
5 48 WS-X4148-RJ JAE0621004W Hw : 3.1
6 48 WS-X4148-RJ JAB054100GR Hw : 3.0
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 40206K 25330K 16384K 5520K 10864K 480K 394K 86K
Uptime is 1 day, 14 hours, 17 minutes
CAT4006-S1>
Re: How to set-up privilege accesses level in Cisco 4006 cat swi
there is no privilege accesses level scalability in CatOS.
Just user (normal,exec, non-privileged) level and enable (privileged) level.
You can go to the enable level by "enable" command (need to know the enable password) and change the config.
But no privilege accesses level tuning like in IOS.
See http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_1/config/cli.htm#1038853 for details.
Milan
Community Member
Hi, Milan
Thanks for your web link.
Kevin
Community Member
Hi, Milan
Kevin
Community Member
Hi, Milan
Kevin
171
