Community Member
How to split the network port in Cisco 7937 phone?
There is only one port in the Cisco Unified IP Conference Station 7937G and I need 2 ports in the meeting room.
Do you know how can I split this port for 2? Maybe Cisco has proper equipment for this purpose?
Galit
Everyone's tags (1)
1 REPLY
Community Member
You cant. From the
You cant. From the documentation - "The internal Ethernet port allows for a direct connection to a 10/100BASE-T Ethernet network through an RJ-45 interface with single LAN connectivity for the Cisco Unified IP Conference Station 7937G. Co-locating a PC with the Cisco Unified IP Conference Station 7937G is not supported."
If you need to connect a second device, then you need to either:
  • Have another cable installed
​or;
  • Connect a small switch to the existing datapoint (configure each switchport as appropriate), and then connect the conference phone to the switch.
Hope that helps,
Steve
203
