Community Member
How to sync running and start configs - Cw2k Win2k
Hello..
I am trying to find an easy way copying run to start. It's great u get a report but there does not seem to be an option to write to mem when forcing the download to device through the - Device config Quick view report. Nor can I do this by using net config or Config editor to force a sync as the applet by default expects a change.
Community Member
Re: How to sync running and start configs - Cw2k Win2k
Create an ad hoc change in netconfig.
Enter the command
copy run start
in the job. Probably you will wish to save it as a template.
Community Member
Sweeet .,..
John
101
