06-10-2003 08:09 AM - edited 03-02-2019 08:01 AM
All,
What command do you use to look for the uptime for a particular port on 5002
CAT?
Steve
06-10-2003 08:13 AM
Cannot get per port uptime using CLI
06-10-2003 08:26 AM
Thanks for the reply. What other method can you use to find out the port uptime? I am trying to troubleshoot whether there is an up and down network connectivities on a particular port on the switch.
Steve
06-10-2003 08:49 AM
I have seen customers use SNMP MIBs to get this information
06-10-2003 11:16 AM
Do you know what the oid is off hand?
Steve
06-10-2003 11:18 AM
a sh logging buffer 1024 may show you
06-10-2003 12:08 PM
No, it only shows mod and current date and time.
Steve
