Community Member
How to tell uptime per port on 5002 CAT
All,
What command do you use to look for the uptime for a particular port on 5002
CAT?
Steve
Re: How to tell uptime per port on 5002 CAT
Cannot get per port uptime using CLI
Community Member
Thanks for the reply. What other method can you use to find out the port uptime? I am trying to troubleshoot whether there is an up and down network connectivities on a particular port on the switch.
Steve
I have seen customers use SNMP MIBs to get this information
Community Member
Do you know what the oid is off hand?
Steve
Silver
a sh logging buffer 1024 may show you
Community Member
No, it only shows mod and current date and time.
Steve
111
