How to tell what IP addresses are on other side of port
Gurus,
On my catalyst 3560's, how can I determine the IP addresses of the devices that are plugged into the ports of the switch?
Thank you!
1 REPLY
Re: How to tell what IP addresses are on other side of port
The easiest way is to look at the MAC address that is learned on a given port, and then cross reference that with the MAC portion of the ARP entry on the default gateway for that VLAN.
HTH,
Bobby
230
